uniform scaling of y-axis and getting bars to appear
I'm using Graph Builder to build a bar graph. I would like uniform scaling of the y-axis because currently all the values are compressed into a small area on the y-axis. However, I can't find where I can request uniform scaling. When I click on the y-axis, a uniform-scaling option does not come up and I can't find such an option elsewhere.
Additionally, I am getting short horizontal lines at the exact values of my data on the y-axis when what I want is bars that extend down to the x-axis (I chose the "bar" option for the graph). I'm using JMP Pro 17 Any ideas? Thank you.
Re: uniform scaling of y-axis and getting bars to appear
Could you show image of your bar chart as normally bar charts look like this in JMP
You could for example have bar style as Float and then you get something like this
Thank you. Yes, the float style is exactly what I'm getting (see attached) but the graph isn't responding to my attempts to change the style.
My guess is that you have non-continuous y-axis (maybe it isn't even numeric). If I change my height column to nominal, I will end up with graph like this
so make sure you have correct data AND modeling type for your column(s)
Thank you. I will check on this issue.
Level XII
Here is a free introductory course to learn the basics of  JMP:
Getting Started with JMP
100% worth the time!
Within the next day you will already get a N-fold return of investment.
I wish there was a stock on the market with such a wonderful payback.
