AdirZig
unable to pass string to function
I am trying to pass to string to function, but its no working.
could someone advise what I do wrong?
// function
C_SC_PC_func2 = Function(
    {SheetName, selSRM},
//call function
C_SC_PC_func2( "string1", "string2" );
Re: unable to pass string to function
I am not seeing an issue. Below is your code, with a Show() function, that gives results that indicates the string variables are passed in.
// function
C_SC_PC_func2 = Function( {SheetName, selSRM},
	Show( sheetname, selsrm );
//call function
sheetname = "string1";
selsrm = "string2";
Craige_Hales
@AdirZig  - you want the comma, not the semicolon, to make a list of local variables in the function. (Your list was empty, and I often start my function definitions with an empty list too.)
// function
	{i,j}, // use comma
	i=3;
	j=4;
//call function
i = j = 0;
show(i,j);
JMP looks at the function function to see if it has three arguments. If it does, and the second argument is a list, it is a list of local variables. If you use a semicolon (making two arguments to function), it becomes a statement in the function body that is evaluated and thrown away.
Craige
