jorge_perez
sub-categorizing columns of data
Hi, 'I am trying to find a way to subdivide the columns into different groups but allowing them to be in multiple gropus at the same time or being able to filter them easily. Lets say I have multiple suppliers for steel and aluminum and i want to be able to analyze only certain suppliers or i want to analysze all the parts made with steel no matter who the supplier is or by process. this would be used for a much much larger number of suppliers and products.
Thanks
 supplier 1supplier 2
 steel aluminum steel aluminum
 die casting stamping die casting stamping die casting stamping die casting stamping
1
2
3
4
5
Re: sub-categorizing columns of data
You can use a Data Filter, or a Local Data Filter to do the subsetting you are referencing.  And if necessary, you can easily create a new column which is a concatenation of the multiple columns, and then use a Data Filter or a Local Data Filter to subset into whatever combination of selections.
jorge_perez
jorge_perez
thanks.
