Françoise
slideshow
bonjour,
je voudrais un modèle de slideshow (comme l'image ci-dessous) pas dans un journal mais un dashboard construit avec jsl.
est-ce possible?  comment faire?
Re: slideshow
The very excellent Journal Text Sledgehammer Add-in, made by @brady_brady can do this for you. Also, here's a link to a video of @ruthhummel explaining how to use all the features.
Françoise
Re: slideshow
Bonjour,
merci pour votre réponse.
je ne veux pas créer un slideshow dans un journal mais un dashboard, donc par un script.
cordialement
Re: slideshow
You could likely copy/adapt the script that the Sledgehammer Add-in is using. A quick way to get to the Add-in folder is to use View...Add-ins, then click the link to go to the Add-in folder. In it, there's a SlidesIntoJournal.jsl script that could serve as a base for your needs.
