kuannygoh
set title for control chart open in mulitple tab
Hi all ,
I would like to change the title of each of my individual  control chart opened in various tab , i have tried set title  ("xxx") but it apprears error , anyone can help ?
For( i = 1, i <= n Items(losscode), i++,
	TB << Add(
		losscode[i],ob1 = Outline Box( "Pareto Chart",
						dt << Control Chart Builder(
	Show Capability( 0 ),
	Variables( Subgroup( :weight ), Y( :height ) ),
	Chart( Position( 1 ), Limits( Sigma ) ),
	Chart( Position( 2 ), Limits( Sigma ) ),
	Where( :name == losscode[i] ))
Re: set title for control chart open in mulitple tab
You are very close to getting the syntax correct.  However, if you look at the Tree Structure of the output from the Tab Box() you are creating, you will see that for each tab within the Tab Box() there is a Tab Page Box().  It is within that object that you send the message to change the Title
Here
I suggest that you read up on Tree Structures in the Scripting Guide
     Help==>Books==>Scripting Guide
Here is a sample script
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
summarize(dt,losscode=by(:sex));
nw=new window("Window", tb=tab box());
For( i = 1, i <= N Items( losscode ), i++,
	TB << Add(
		losscode[i],
				Where( :sex == losscode[i] )
tb[tabpagebox(1)]<<title("Female");
tb[tabpagebox(2)]<<title("Male");
If you want to change the Control Chart Builder to something else, that is just a simple extension off of my previous response
	TB << Add(
		losscode[i],
tb[tabpagebox(1)][OutlineBox(2)]<< set title("Female");
tb[tabpagebox(2)]["Control Chart Builder"] << set title("Male");
Here
	TB << Add(
		losscode[i],
kuannygoh
Ths nelson ,
But i wanted to change the title of the control chart builder inside female tab instead of the female tab .
	TB << Add(
		losscode[i],
