  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
PeimeiDa
set row color by given RGB values
Hi, I'm trying to set row color (not cell color) by given RGB values in my columns. However, i can not get the correct loop for assigning the custom colors that I want. Could anyone help?
Code and datatable attached. Thanks!
// Get the current data table
// Initialize the color lists
RedList = Column(dt, "Red") << Get Values;
GreenList = Column(dt, "Green") << Get Values;
BlueList = Column(dt, "Blue") << Get Values;
// Ensure we do not exceed the number of rows or the number of items in any color list
minLength = Min( N Rows(dt), N Items(RedList), N Items(GreenList), N Items(BlueList) );
// Loop to set the row colors
For( i = 1, i <= minLength, i++,
    // Clear any previous selections
    dt << Clear Select;
    // Select the current row
    dt << Select Where( Row() == i );
    // Set the row color
    dt << Set Row Colors( RedList[i], GreenList[i], BlueList[i] );
Re: set row color by given RGB values
This will be a bit slow due to all selections happening
dt << show window(0);
For Each Row(dt,
	dt << Clear Select;
	dt << Select Rows(Row());
	dt << Colors(RGB Color(Eval List({:Red, :Green, :Blue}) / 255));
dt << show window(1);
if more speed is required it could be made faster by selection multiple rows (all rows which have specific color at the same time) or by setting row states.
Summarize(dt, uniq = By(:Color), r = Min(:Red), g = Min(:Green), b = Min(:Blue));
For Each({cur_color, idx}, uniq,
	dt << Select Where(:Color == cur_color);
	dt << Colors(RGB Color(Eval List({r[idx], g[idx], b[idx]}) / 255));
	dt << Clear Select;
Nice picture!
Edit:
Just came to my mind that you could also use Summary table to set the colors
dt_summary = dt << Summary(
	Group(:Color),
	Mean(:Red),
	Mean(:Green),
	Mean(:Blue),
	Freq("None"),
	Weight("None"),
	statistics column name format("column")
For Each Row(dt_summary,
	dt_summary << Select Rows(Row());
	dt_summary << Colors(RGB Color(Eval List({:Red, :Green, :Blue}) / 255));
	dt_summary << Clear Select;
Close(dt_summary, no save);
Edit2: One more option looping over the whole table but without selections
For Each Row(dt,
	Row State(Row()) = Color State(Eval List({:Red, :Green, :Blue} / 255));
I couldn't figure out how to convert Color State (for example Color State(-15527920)) to number (should be 512.925536155701) so I could have built row state matrix and use << Set Row States.
For Each Row(dt,
	dt << Clear Select;
	dt << Clear Select;
Nice picture!
Edit:
	Group(:Color),
	Mean(:Red),
	Mean(:Green),
	Mean(:Blue),
	Freq("None"),
	Weight("None"),
For Each Row(dt,
PeimeiDa
Thanks! These solutions are truely effective, and efficient!
Sorry to dredge up an older post, but I learned something about this just now after struggling for a bit. I was also trying to convert Color States to numbers without success. Instead, I found a way that's even faster as it avoids looping. It feels like cheating, but creating a formula column, then letting JMP use the built-in function to copy those row states was significantly faster than @jthi's previously very fast Edit2 version.
(dt << new column ("Color", formula (color state (RGB color (:R, :G, :B))))) << copy to row states;
2 things
  1. The syntax for setting the color of the row state color was incorrect.
  2. Using the Select Where() made the looping very slow.
Here is my modification
    dt << Clear Select;
    dt << Select rows( i );
    dt << Colors( rgb color(redlist[i],greenlist[i],bluelist[i]) );
