AiSm
set background image to vlistbox/lineupbox
I designed an UI like this. Wanna set a background picture to the whole page, not sure how to do it. below is my code:
HomeWindow = New Window( "Home",
	HomeVlistbox = V List Box(
		Lineup Box( N Col( 3 ),
			spacerLoginLeft = Spacer Box(),
			V List Box(
				loginTitle = Text Box( "Welcome" ),
				loginPanelBox = Panel Box( "",
					loginLineUpBox = Lineup Box( N Col( 2 ),
						userNameTextBox = Text Box( "User Name" ),
						userNameTextEditBox = Text Edit Box( Get Environment Variable( "USERNAME" ) ),
						passwordTextBox = Text Box( "Password" ),
						passwordTextEditBox = Text Edit Box(),
						loginType = Check Box( "Auto" ),
						loginButtonBox = Button Box( "Login", loadScriptFunction( "loginAction" ) )
			spacerLoginRight = Spacer Box()
Craige_Hales
Re: set background image to vlistbox/lineupbox
JMP mostly doesn't use images for backgrounds behind controls. You can use a background color in a container box and many child boxes will show the parent's background color.
If you really need to do it anyway, you might try making a file->new->application. Build the gui first, then add a Pict Box. Your gui elements and the PictBox will be siblings in the application (pict box is not a container.) What you drag last will move to the background (because it moves to the front of the list and draws first), so drag the picture last.
Not a great image choice for a background--too busy!Not a great image choice for a background--too busy!
Craige
Craige_Hales
Craige
AiSm
JMP, so far, looks not good at fancy interactive User Interface. But your solution is helpful! Thanks a lot!
