DavidLeber
selectWhere on column attributes
I'm trying to select all columns which have the attribute "Units", and where the "Units" attribute has a value of "kg/hr". Is there some way to do a clean selectWhere, or do I need to iterate through each column to collect them?
jerry_cooper
Staff (Retired)
Re: selectWhere on column attributes
Selecting columns with specific properties, such as "Units", can be done without JSL from the Cols->Columns Viewer menu by clicking on the "Find Columns with Properties" button and then selecting the "Units" check box. This will return a table with a 'Yes' or 'No' for the "Units" property. Sorting this table by right-clicking and selecting "Sort by column..." and then selecting "Units" will make it easy to select all columns with a "units" property.
However, to select a specific unit, such as "kg/hr", would require iterating through your columns as you guessed. This would only take a few lines of JSL, something like:
For( i = 1, i <= N Cols( dt ), i++,
	If( Column( i ) << Get Property( "Units" ) == "kg/hr",
		Column( i ) << set selected
Hope this helps.
cwillden
As far as I know, there is no existing function that would spare you from iterating through your columns and checking them individually.  You could subset the columns you need to look at by getting a list of all numeric columns (e.g. numeric_cols = dt << Get Column Names(Numeric, Continuous)).  Unless you have a ridiculous number of columns, that probably won't make a noticeable difference in reducing compute time to execute that task.  Luckily, it's not very hard to do.
-- Cameron Willden
jerry_cooper
Staff (Retired)
Hope this helps.
GianpaoloP
i create for my columns a  property called METADATA with info TEST
when i tried to select this columns the script doesn't show error, but the columns are not selected
can you help me?
If( Column( i ) << Get Property( "METADATA" ) == "TEST",
Column( i ) << set selected (1),
thanks in advance
Gianpaolo
