tangxu
select parts outside of limits
I have multiple columns for which I have set limits. How can I select the rows that are outside the limits?
Re: select parts outside of limits
You can also accomplish this via the Process Capability platform.
dt=Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
Process Capability(
	Process Variables( :NPN1, :PNP1, :PNP2 ),
	Moving Range Method( Average of Moving Ranges ),
	Overall Sigma Normalized Box Plots( 1 ),
	Select Out of Spec Values( 1 ),
	Goal Plot( 1 ),
	Capability Index Plot( 1 ),
	Process Performance Plot( 0 )
I am assuming you want to do this selection using a script.
Here is a script to select rows based upon the rows outside of spec limits for one variable
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
specs = dt:PNP1 << get property("spec limits");
dt << select where( dt:PNP1 <= specs["LSL"] | dt:PNP1 >= specs["USL"]);
Here is script for multiple columns
//colNames = dt << get column names( continuous, string );
colNames = { "PNP1", "PNP3"};
For( i = 1, i <= N Items( colNames ), i++,
	specs = Column( dt, colNames[i] ) << get property( "spec limits" );
	If( Try( Is Missing( specs["LSL"] ) ) == 0 & Try( Is Missing( specs["USL"] ) ) == 0,
		found = dt << get rows where(
			as Column( dt, colNames[i] ) <= specs["LSL"] | as Column( dt, colNames[i] ) >= specs["USL"]
		If( N Rows( found ) > 0,
			dt << select rows(found);
tangxu
Thank you. This works. Is there any manual way instead of script? if i have already selected multiple columns and plotted the distribution, is there any manual way to select failure parts?
You can right click on the row state column and select ...select rows=>select where
If you are looking for a way to do this via the distribution platform, you can hold down the Ctrl key while clicking histogram bars of interest.  This will select the corresponding rows in the data table.
Process Capability(
	Goal Plot( 1 ),
