- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
select parts outside of limits
I have multiple columns for which I have set limits. How can I select the rows that are outside the limits?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: select parts outside of limits
Created:
Jan 27, 2021 10:21 AM
| Last Modified: Jan 27, 2021 7:25 AM
(2230 views)
| Posted in reply to message from tangxu 01-26-2021
You can also accomplish this via the Process Capability platform.
dt=Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
Process Capability(
Process Variables( :NPN1, :PNP1, :PNP2 ),
Moving Range Method( Average of Moving Ranges ),
Overall Sigma Normalized Box Plots( 1 ),
Select Out of Spec Values( 1 ),
Goal Plot( 1 ),
Capability Index Plot( 1 ),
Process Performance Plot( 0 )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
I am assuming you want to do this selection using a script.
Here is a script to select rows based upon the rows outside of spec limits for one variable
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
specs = dt:PNP1 << get property("spec limits");
dt << select where( dt:PNP1 <= specs["LSL"] | dt:PNP1 >= specs["USL"]);
Here is script for multiple columns
//colNames = dt << get column names( continuous, string );
colNames = { "PNP1", "PNP3"};
For( i = 1, i <= N Items( colNames ), i++,
specs = Column( dt, colNames[i] ) << get property( "spec limits" );
If( Try( Is Missing( specs["LSL"] ) ) == 0 & Try( Is Missing( specs["USL"] ) ) == 0,
found = dt << get rows where(
as Column( dt, colNames[i] ) <= specs["LSL"] | as Column( dt, colNames[i] ) >= specs["USL"]
If( N Rows( found ) > 0,
dt << select rows(found);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Thank you. This works. Is there any manual way instead of script? if i have already selected multiple columns and plotted the distribution, is there any manual way to select failure parts?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
You can right click on the row state column and select ...select rows=>select where
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
If you are looking for a way to do this via the distribution platform, you can hold down the Ctrl key while clicking histogram bars of interest. This will select the corresponding rows in the data table.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Created:
(2231 views)
Process Capability(
Goal Plot( 1 ),
