Ohad_s
script to subset selected rows
I have the following script:
I Want to select some rows and subset them.
selection finds 369 rows, but subset only 140 rows.
Does someone have any idea what I am missing?
dt = Current Data Table();
Column(dt, "DieX") << data type(Numeric) << Modeling Type(Continuous) << Format(Best, 12);
Column(dt, "DieY") << data type(Numeric) << Modeling Type(Continuous) << Format(Best, 12);
dt << select where(
	1045 <= :DieX <= 1055 & 1221 <= :DieY <= 1228
	| 1145 <= :DieX <= 1155 & 1221 <= :DieY <= 1228
	| 1045 <= :DieX <= 1055 & 770 <= :DieY <= 778
	| 1145 <= :DieX <= 1155 & 770 <= :DieY <= 778
dt_subset = dt << subset(output table("Defects"), selected rows(1));
Re: script to subset selected rows
For me it seems to subset correct amount of rows (369) (I made slight modifications to your script, but even the original did subset correct amount of rows)
dt = Open("$DOWNLOADS/Setup2_0_2_Surface.jmp");
dt << clear select << Clear Column Selection;
dt << select where(
dt_subset = dt << subset(output table("Defects"), selected rows(1), Selected Columns(0));
dt << select where(
Ohad_s
Thank you!
