AdamChoen
save interactive HTML from journal reset my chart properties
Hi
I have a simple script to generate Bivariate charts
I then move charts to journal (no issue there) and finally save to interactive HTML.
the HTML file contains my charts but all point color marker shape and size was rest.
no issue when i save image or HTML (not interactive) but I really need to use the interactive one.
any help is welcomed.
BTW
I'm not using legend
Thanks, Adam
Re: save interactive HTML from journal reset my chart properties
Adam,
When the Row Legend JSL function is used to create marker shapes and colors, they are stored in the data table's row states.
When you do this, the way they are stored in a journal is not supported by Interactive HTML in JMP 12.
Support for retrieving the row state marker colors and shapes from journals when exporting to Inteactive HTML was introduced in JMP 14.
If you save each report to interactive HTML without storing it in a journal first, the colors will be maintained.
-John
Hi Adam,
I'd like to see if I can recreate the problem you're seeing.
It would help to know what JSL commands are you are using to set the marker colors/shapes and what version of JMP you are using.
If you are able to share your script (using anonymized or random data if you need to), that would also be useful.
Thanks,
~John
AdamChoen
Hi John,
I'm having this issue for any chart I try to save as interactive, I'm using JMP pro 12
see example
dt = data table ("CE_Warn_RawData");
lst = dt << Bivariate(
				Y( :value ),
				X( :run_start_date ),
				BY( :name, :window, :var, :stat),
					Dispatch( {}, "2", ScaleBox, {Add Ref Line( 0, "Dashed", "Black", "", 1 )} ),
					Dispatch(
						"Bivar Plot",
						FrameBox,
						{Frame Size( 700, 200 ),Row Legend(
							subentity,
							Color( 1 ),
							Color Theme( "JMP Default" ),
							Marker( 1 ),
							Marker Theme( "Standard" ),
							Continuous Scale( 0 ),
							Reverse Scale( 0 ),
							Excluded Rows( 0 )
lst << Journal();
Current Journal () << Save interactive HTML ("\\.....\RawData.html");
Thanks, Adam
Adam,
-John
