HarryG
removing {} from << get selected variable
the output below puts { } on the date_selection variable. How do I remove the brackets.
output = {"date1"};
desired output = "date1";
date_list = Column( 2 ) << get values;
Show( date_list );
run_select = New Window( "checkboxes",
	<<modal(),
	V List Box(
		cb_list = Check Box( date_list ),
		Button Box( "OK", date_selection = cb_list << get selected )
12 REPLIES 12
ankitgssingh
Re: removing {} from << get selected variable
It is not actually a date column. It is a list of column names which are all categorical. So when I say contact, I dont want to concat the column names. I want to contact the data in those columns together and make a new column out of it. So cannot use "concat Items" as I think it would concat the column names not their values.
ankitgssingh
Thank you. This solved my query.
ankitgssingh
Thank you for this solution. Works just fine.
Had one question, what if the column names have '/' in them and don't work directly without using ":name(column name)" ? Any way of using ":name(column name)" instead of just "column name" ?
Thanks in Advance.
