dadawasozo
remove string that contains number from text
 is that a way to remove any string that contain numbers using JSL?
Example:
I ate 4 apples and 2 bananas
the model number is 0998GBELS
03/45 is the ratio to check
Targeted Output:
I ate apples and bananas
the model number is
Re: remove string that contains number from text
This works, but someone familiar with Regular Expressions would be able to simplify the script
theString = "I ate 4 apples and 2 bananas
03/45 is the ratio to check";
theList = Words( theString, " \!n\!r\!t" );
adjustedString = "";
For Each( {member}, theList,
	Show( member );
//member=thelist[1]
	found = "No";
	If( !Contains( member, "0" ),
		If( !Contains( member, "1" ),
			If( !Contains( member, "2" ),
				If( !Contains( member, "3" ),
					If( !Contains( member, "4" ),
						If( !Contains( member, "5" ),
							If( !Contains( member, "6" ),
								If( !Contains( member, "7" ),
									If( !Contains( member, "8" ),
										If( !Contains( member, "9" ),
											adjustedString = Trim( adjustedString || " " || member )
Show( adjusted String );
dadawasozo
I have many lines to process (in hundred millions), doing so will cause higher latency. I wonder if there is a better way to remove those strings that contain number with lower latency ?
Not sure i this would work in all situations but it does for these examples
strs = {
"I ate 4 apples and 2 bananas",
"the model number is 0998GBELS",
"03/45 is the ratio to check"
result2 = Transform Each({str}, strs,
	Regex(str, "\w*\S*\d+\w*\S*", "", GLOBALREPLACE)
show(result2); // result2 = {"I ate apples and bananas", "the model number is ", " is the ratio to check"};
Edit:
I think that regex can be simplified a bit to
Regex(str, "\S*\d+\S*", "", GLOBALREPLACE)
https://regex101.com/r/PM4UQn/1
