katjes
reading data from peak - y and x data
I am having JMP 18 and I am looking for a way to read the max peak - I´d like to have the max y and equivalent x value.
Re: reading data from peak - y and x data
It requires just a simple modification to the JSL I originally provided.
names default to here(1);
dt = current data table();
// Find all of the peaks
theRows = (dt << get rows where(col max(:signal, :ID)==:signal));
// Display results
New window("Peak Maximums",
	table box(
		string col box("ID", :ID[theRows]),
		number col box("time, min",:"time, min"n[theRows]),
		number col box("signal", :signal[theRows])
// Select the rows in the data table
dt << clear select;
dt << select rows(theRows);
Here is a simple script that will write the values to the log
theRow = (dt << get rows where(col max(:signal)==:signal))[1];
show(:"time, min"n[theRow],:signal[theRow]);
katjes
hi, thanks for the great input.
Is there away that it does the data picking for all IDs?
// Display results
	table box(
dt << clear select;
