I think this post may help you:
Solved: Weighted Standard Deviation - JMP User Community
And probably the following script helps to understand what can happen.
So in your approach calculation of mean works, whatever method you take (role weight or frequency).
I made a different definition of weight in comparison to yours, I wanted the total sum of weights to be 1200 (you have 4*1200).
This should not matter, and for weight in the role of frequency it does not, but for weight in role weight it does. See script.
Unfortunately I cannot exactly explain why, the small dataset gets a very large stddev in comparison to the total average. Its perhaps due to square and root ...
I personally would not use your approach, because it's not clear, what is happening. I would do the group summary, and then the average over groups each weighted 1. And then combine that result into your graph.
// about the role of weight and frequency for calculation of mean and stddev
// web("https://www.jmp.com/support/help/en/16.1/?os=win&source=application&utm_source=helpmenu&utm_medium=application#page/jmp/summary-statistics.shtml");
nelem_lst = {100, 500, 200, 400};
table_lst = {};
For Each( {value, index}, nelem_lst,
Eval(
Eval Expr(
table_lst[index] = New Table( "Table " || Char( index ),
add rows( nelem_lst[index] ),
New Column( "Group", "Character", set each value( "Group " || Char( index ) ) ),
New Column( "Type", "Character", set each value( If( index <= 2, "Type 1", "Type 2" ) ) ),
New Column( "DV", "Continuous", formula( Random Normal( Expr( Mod( index, 2 ) ), Expr( Mod( index, 2 ) + 1 ) ) ) )
Wait( 0.1 );
table_lst[index]:DV << delete formula;
Wait( 0 );
dt = table_lst[1] << concatenate( Table Name( "All" ), table_lst[2 :: 4] );
For Each( {value}, table_lst, Close( value, "NoSave" ) );
Summarize( dt, group_lst = by( :group ) );
ngroups = N Items( group_lst );
dt << New Column( "ColMean[Group]", formula( Col Mean( :DV, :group ) ) );
dt << New Column( "ColStd[Group]", formula( Col Std Dev( :DV, :group ) ) );
Eval( Eval Expr( dt << New Column( "weight[Group]", formula( Col Number( :DV ) / Expr( ngroups ) / Col Number( :DV, :group ) ) ) ) );
nw = New Window( "oneway comparison",
H List Box(
Panel Box( "w/o weight",
dt << Oneway( Y( :DV ), X( :Group ), Means and Std Dev( 1 ), Mean Error Bars( 1 ), Std Dev Lines( 1 ) );
Panel Box( "weight in role frequency",
dt << dt << Oneway(
Y( :DV ),
X( :Group ),
Freq( :"weight[Group]"n ),
Std Dev Lines( 1 )
Panel Box( "weight in role weight",
dt << dt << Oneway(
Y( :DV ),
X( :Group ),
Weight( :"weight[Group]"n ),
Std Dev Lines( 1 )
nw = New Window( "Tabulate comparison",
H List Box(
dt << Tabulate(
Change Item Label( Grouping Columns( :Type( "All" ), "All" ) ),
Add Table(
Column Table( Statistics( N ) ),
Column Table( Analysis Columns( :"weight[Group]"n ), Statistics( Sum ) ),
Column Table( Analysis Columns( :DV ), Statistics( Mean ) ),
Column Table( Statistics( Std Dev ), Analysis Columns( :DV ) ),
Row Table( Grouping Columns( :Type, :Group ), Add Aggregate Statistics( :Type, :Group ) )
dt << Tabulate(
Add Table(
dt << Tabulate(
weight( :"weight[Group]"n ),
Add Table(
dt << Summary( Group( :Group, :Type, :"ColMean[Group]"n, :"ColStd[Group]"n, :"weight[Group]"n ), Freq( "None" ), Weight( "None" ) );
Georg
