Yes, strength relative to the other effects in the model. BTW, I always recommend you do these plots with a saturated model.
Also of note, if the signs of the factor settings are meaningful (i.e., continuous factors), then you can use normal plots and take advantage of the directional vector. A paper to read if you don't have access to his excellent book:
Daniel, Cuthbert (1959) "Use of Half-Normal Plots in Interpreting Factorial Two-Level Experiments", Technometrics, Vol. 1, No. 4, November
