tomerFire
"Specified Column not found in data table" in Fit Model using JSL
I have a script that makes a Fit Model from a table I import.
My problem is that I get this error when accessing the data.
"Specified Column not found in data table.{4759} in access or evaluation of 'List' , {/*###*/data:T_VALUE}"
When I try to access the column through "Show" I get good results:
"data:T_VALUE = 1;"
My code:
data = Open( "C:/Users/taviad/Desktop/Sheet1.jmp" );
					Show(data:T_VALUE);
					model = data << Fit Model(
					Y( data:T_VALUE ),
					Effects(
						data:x,
						data:y,
						data:z,
						data:c
					Emphasis( "Minimal Report" ),
					Run(),
					Where( data:b == "param1" & data:n == "param2" ),
Thanks.
tomerFire
Re: "Specified Column not found in data table" in Fit Model using JSL
I managed to solve it be resaving the data on a new file. I dont know what was the problem but the original file was not good.
7 REPLIES 7
It is possible that JMP has not finished opening your data table, when it is going ahead and running the Fit Model.  If that is the case, by adding in a Run Formulas request will force JMP to complete the Open() function, and should fix the issue.
data << run formulas;
	Y( data:T_VALUE ),
	Effects( data:x, data:y, data:z, data:c ),
	Run(),
tomerFire
Hi, thanks for the answer.
I tried it and I got the same error:
data:T_VALUE = 1;
Is T_VALUE a data column or a table variable? Fit Least Squares requires a data column in the Y role.
tomerFire
Its a column. It is ok like this?
gzmorgan0
The log messages you reported look strange.
  • "Specified Column not found in data table.{4759} in access or evaluation of 'List' , {/*###*/data:T_VALUE}" this is not the error message I get if I specify a column that does not exist. This looks like an error message when you have a list specified for Y
  • When I try to access the column through "Show" I get good results:   "data:T_VALUE = 1;" This will occur when T_VALUE is a table variable and no column with that name exists
  • This is the results of a Show when data has a column with that name  is "data:T_VALUE = .;"
Just in case your column name is read in with a CR or tab you might want to try the script below, it removes leading and trailing spaces and tabs and line feeds and carriage returns(new line)
for(i=1, i<=ncol(data), i++,
	column(data,i) << set name( Trim( column(data,i) << get name) );
I just don't undestand the error: "T_VALUE = 1". That makes it look like a scalar value, not a column.
tomerFire
