I have a script that makes a Fit Model from a table I import.
My problem is that I get this error when accessing the data.
"Specified Column not found in data table.{4759} in access or evaluation of 'List' , {/*###*/data:T_VALUE}"
When I try to access the column through "Show" I get good results:
"data:T_VALUE = 1;"
My code:
data = Open( "C:/Users/taviad/Desktop/Sheet1.jmp" );
Show(data:T_VALUE);
model = data << Fit Model(
Y( data:T_VALUE ),
Effects(
data:x,
data:y,
data:z,
data:c
Emphasis( "Minimal Report" ),
Run(),
Where( data:b == "param1" & data:n == "param2" ),
Thanks.
