vince_faller
"Program type out of range" warning
What is this for trying to tell me?  I'm seeing it a lot lately.  It doesn't appear to crash things, but it's a little disconcerting.
Vince Faller - Predictum
Jeff_Perkinson
Re: "Program type out of range" warning
Are you doing any ODBC stuff? The only references I've found relate to issues fetching data from a database with ODBC.
It may be best to take this up with Tech Support to track down.
-Jeff
Jeff_Perkinson
We're going to need some details to help here. What are you trying to do when you see this error? Does the error appear in a dialog box or in the log?
-Jeff
vince_faller
I'm doing some DOE stuff currently but I've seen it in multiple spots.  It comes up in the log right now but it's because I'm scripting.  It happens 4 or 5 times in the script I run but I haven't narrowed down which part of the script is actually causing it.  Does it mean different things in different spots?  Does it mean something in general?
Jeff_Perkinson
-Jeff
vince_faller
Yeah. I'm doing ODBC stuff in a lot of places. I'll check out my odbc calls then.  Thanks.
Craige_Hales
Jeff's right, need more info. I'm having no luck finding where JMP might generate that message.
Craige
