db84
"Create Process Capability" Option not seen under "Distribution" in JMP 16 trial. Please advise.
Re: "Create Process Capability" Option not seen under "Distribution" in JMP 16 trial. Please advise.
Does your table have any specification limits set? Using Big Class as an example.
After opening and immediately trying to create Process Capability (no option available):
After adding specification limit column property to height column:
Edit:
You can also do Capability Analysis from the distribution platform if you don't have the limits yet, good example Process Capability Analysis , see also this
