Haelavot
printing variable to textbox in variability chart
when i run the following script, the charts are producted for each sample, however the textbox print sampleName instead of actually printing the value of the sample name.  how do i get around this?
thanks!
// Create a new window with variability charts for each sample name
New Window("whiteshirts - Variability Chart",
	V List Box(
		Current Data Table(summaryTable);
		For Each Row(
			summaryTable,
			sampleName = Column(summaryTable, "SAMPLE_NAME")[Row()];
			grandMin = Column(summaryTable, "Min(LAB_L)")[Row()];
			grandMax = Column(summaryTable, "Max(LAB_L)")[Row()];
			Print(sampleName, grandMin, grandMax);
            /*Text Box( "Where(:SAMPLE_NAME == " || char(sampleName) || ")", <<Set Wrap( 1903 ) );*/
			Text Box(Char(sampleName));
			Print("sampleName is " || sampleName);
			Data Table("whiteshirtsall") << Variability Chart(
				Y(:LAB_L),
				Model("Main Effect"),
				X(:shirt),
				Variability Analysis(
					:LAB_L,
					Std Dev Chart(0),
					AIAG Labels(0),
					Show Box Plots(1)
				Where(:SAMPLE_NAME == sampleName),
					Dispatch(
						{"Variability Gauge Analysis for LAB_L", "Variability Chart for LAB_L"},
						"2", ScaleBox,
						{Add Ref Line(grandMin, "Solid", "Medium Dark Red", "", 2),
						Add Ref Line(grandMax, "Solid", "Medium Dark Red", "", 2),
						Label Row({Show Major Grid(1), Show Minor Grid(1)})}
Edit 2024-09-05 jthi: added jsl formatting
Re: printing variable to textbox in variability chart
The text used in filter isn't being evaluated so it will be left as sampleName. Here is one way how you could evaluate it
Column(dt, 2) << Set Name("shirt");
Column(dt, 3) << Set Name("SAMPLE_NAME");
Column(dt, 4) << Set Name("LAB_L");
dt_summary = dt << Summary(
	Group(:SAMPLE_NAME),
	Min(:LAB_L),
	Max(:LAB_L),
	Freq("None"),
	Weight("None"),
	Link to original data table(0),
	output table name("Summary of Big Class grouped by SAMPLE_NAME")
nw = New Window("whiteshirts - Variability Chart",
	V List Box(
		For Each Row(
			dt_summary,
			sampleName = Column(dt_summary, "SAMPLE_NAME")[Row()];
			grandMin = Column(dt_summary, "Min(LAB_L)")[Row()];
			grandMax = Column(dt_summary, "Max(LAB_L)")[Row()];
			Eval(EvalExpr(
				dt << Variability Chart(
					Y(:LAB_L),
					X(:shirt),
						:LAB_L,
						Std Dev Chart(0),
						AIAG Labels(0),
						Show Box Plots(1)
					Where(:SAMPLE_NAME == Expr(sampleName)),
						Dispatch(
							"2", ScaleBox,
	Min(:LAB_L),
	Max(:LAB_L),
	Freq("None"),
	Weight("None"),
	V List Box(
		For Each Row(
			dt_summary,
			Eval(EvalExpr(
					Y(:LAB_L),
					X(:shirt),
						:LAB_L,
						Std Dev Chart(0),
						AIAG Labels(0),
						Show Box Plots(1)
						Dispatch(
							"2", ScaleBox,
