BabyDoragon
How can I output the graph in the same window as the button?
When I write the command to output the graph in the button, it actually outputs in a new window. What should I do to output the graph in the same window (as shown in the figure below)?
nw2 = New Window( "New window",
	outputG = Button Box( "Output Graph",
		Outline Box( "Graph Output",
		Bivariate( y( :weight ), x( :height ) ); )
Re: How can I output the graph in the same window as the button?
The objects created when the button box is clicked need to be appended back to the window.
		ob = Outline Box( "Graph Output",
		nw2 << append( ob );
You could collect them into some display element
nw2 = New Window("New window",
	outputG = Button Box("Output Graph",
		vlb << Append(Outline Box("Graph Output", Bivariate(y(:weight), x(:height))))
	vlb = V List Box()
