anuragg
points on graph not color coded according to legend
I am running into a different issue. I made the variability plots and normal quantile plots so that the points on the graph appear highlighed and color coded according to the legend category but every legend category has turned into a blob of black dots. How can I fix this issue?
current data table(dt);
dt<<bring window to front;
colNameList=dt<< Get Column Names();
vlb=V list Box();
j2=New Window("Plots",<<journal,vlb);
print(colNameList)
For (i=16, i<18, i++,
vp=Expr(
Variability Chart(
	Y( Column(dt,colNameList[i]) ),
	X( :product, :Wafer Category ),
	Max Iter( 100 ),
	Conv Limit( 0.00000001 ),
	Number Integration Abscissas( 128 ),
	Number Function Evals( 65536 ),
	Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
	Std Dev Chart( 0 ),
	Points Jittered( 1 ),
	Show Box Plots( 1 ),
		Dispatch(
			{"Variability Chart for"|| colNameList[i]},
			"Variability Chart",
			FrameBox,
			{Frame Size( 320, 250 ), DispatchSeg(
				Box Plot Seg( 1 ),
				{Box Type( "Outlier" ), Line Color( "Red" )}
			), DispatchSeg(
				Box Plot Seg( 2 ),
			), DispatchSeg(
				Box Plot Seg( 3 ),
			), DispatchSeg(
				Box Plot Seg( 4 ),
			), DispatchSeg(
				Box Plot Seg( 5 ),
			), DispatchSeg(
				Box Plot Seg( 6 ),
			), DispatchSeg(
				Box Plot Seg( 7 ),
			), DispatchSeg(
				Box Plot Seg( 8 ),
		Dispatch(
			{"Variability Chart for " || colNameList[i]},
			NomAxisBox,
			{Set Width( 320 ), Set Height( 100 )}
		Dispatch(
			NomAxisBox( 2 ),
			{Set Width( 309 ), Set Height( 100 )}
dt<<select where(:Wafer Category!="Baseline");
owp=Expr(
Oneway(
	X( :Wafer Category ),
	All Graphs( 0 ),
	Plot Quantile by Actual( 1 ),
	Line of Fit( 0 ),
	Comparison Circles( 1 ),
	X Axis Proportional( 0 ),
	Grand Mean( 0 ),
		Dispatch(
			"Oneway Analysis of "||colNameList[i]|| "By Wafer Category",
			OutlineBox,
			{Set Title( "ProbPlot" )}
		Dispatch(
			{"Normal Quantile Plot"},
			"1",
			ScaleBox,
			{Label Row( Label Orientation( "Vertical" ) )}
		Dispatch(
			"2",
			ScaleBox,
			{Format( "Best", 15 ), Add Ref Line( 0.5, "Solid", "Black", "", 1 ),
		Dispatch(
			"Oneway QuantilePlot",
			FrameBox,
			{Frame Size( 428, 369 ), Row Legend(
				Wafer Category,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 1 ),
				Marker Theme( "Standard" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
		Dispatch(
			PlotColBox,
			{Visibility( "Collapse" )}
		Dispatch(
			StringColBox,
vlb<<append (H List Box(Eval(Eval Expr(vp)),
	           Eval(Eval Expr(owp))
ThuongLe
Re: points on graph not color coded according to legend
Right click inside your Variability Graph and choose Row Legend
Thuong Le
anuragg
 I did and then pasted that script in my JSL script thinking that I will be able to produce the same results for every graph that my for-loop makes but for some reason it does not seem to work. Any ideas why?
