ValeriaL
passing a variable in the Set Property fore a column
Hi all,
can somebody explain how I can pass a variable into, for example, spec limits?
I want the spec limit for the column "dt:frac" to be "uls_value"
So I define the  value:
usl_value=0.05;
and then I tried:
dt:frac <<Set Property( "Spec Limits", {USL(eval(usl_value)), Show Limits( 1 )} );
dt:frac <<Set Property( "Spec Limits", {USL(expr(usl_value)), Show Limits( 1 )} );
dt:frac <<Set Property( "Spec Limits", {USL(usl_value), Show Limits( 1 )} );They are all scriptable but none does the trick.
Thanks
ErraticAttack
Re: passing a variable in the Set Property fore a column
In JSL lists are unevaluated, so anything within a list that you want evaluated you'll need to wrap in an Eval( Eval Expr( ... ) ) function, such as this:
Eval( Eval Expr(
	dt:frac << Set Property( "Spec Limits", {USL( Expr( usl_value ) ), Show Limits( 1 )} )
Jordan
