Jacxo
new formula column in jmp 15 on a mac
For class I need to use the new formula column but in the video the professor provided us where the new formula is on his version on windows is not where it is on my mac. I am having a hard time finding it to use.
thank you,
Jacqueline
Re: new formula column in jmp 15 on a mac
Hi @Jacxo ,
If you can right click (or Control click)  on the column header of interest, you should see an item called New Column Formula.  See attached image.
Screen Shot 2021-07-28 at 16.45.50.pngScreen Shot 2021-07-28 at 16.45.50.png
Chris Kirchberg, M.S.2
www.jmp.com
