Bhasemeier
JSL for Control chart Text Box
I utilize a script which creates a control chart with a nested where statement. The script runs properly, however, the final output of the script  generates a small text box above my control chart frame box with my where statement clause. When this script is saved into my final report through powerpoint or text, a new page is created of this where statement text box for each chart.
Is it possible to add JSL language to delete or edit this text box or to not print the text box?
Re: JSL for Control chart Text Box
Here is a script that will illustrate how to delete the displayed Where Clause
// Open Data Table: big class.jmp
// → Data Table( "big class" )
Open( "$SAMPLE_DATA/big class.jmp" );
Control Chart Builder(
	Test Excluded Subgroups( 1 ),
	Variables( Y( :height ) ),
	Where( :sex == "F" )
current report()[textbox(1)]<<delete;
See the section in the Scripting Guide on Display Trees for documentation on the manipulation of output like this.
Bhasemeier
Thank you for the quick response.
Is there a way to clearly identify which text box this is used in? I have to also apply this to some for loops where it seems there is a dynamic text box call out and I cannot find the properties for which text box number I need to delete.
Here is an example of the for looping function I am trying.
ncol = N Col( Data Table( "big class" ) );
combo = V List Box();
w = New Window( "Run Charts",
    H List Box( combo )
For( i = 4, i <= ncol, i++,
    plot = V List Box(
            Variables( Y( Column( i ) ) ),
    combo << append( plot );
    Current Report( combo )[Text Box( i - 3 )] << delete;
Given the structure of how you are approaching your analysis, I would handle the deletion of the text box, by deleting it before appending the output to your V List Box.
    H List Box( combo )
    plot = V List Box(
        cc = Control Chart Builder(
    (report(cc)<<parent)[textbox(1)]<<delete;
The report element for a platform points to the first Outline Box() in the report, not to the HeadBox() as the Current Report() function does.  Therefore, one needs to move to the parent above the first OutlineBox() and the find the first text box() from that point.
