AdamChoen
new column with all value set to zero
Hi
how can I create a new numeric column with all values are zero and not empty?
thanks!
Thanks, Adam
Re: new column with all value set to zero
dt<<new column("All Zeros", set each value(0));
See the Scripting Index for details about this
     Help==>Scripting Index==>Data Table==>Column Scripting
Create your new column, then go to the Column Info for the column, click on the down arrow for "Initialize Data" and select "Constant".  Then enter in your "0" and clock OK
AdamChoen
thank Jim,
I forgot to ask for it, can I write it in JSL?
Thanks, Adam
AdamChoen
As always, work great. Thank you Jim
Thanks, Adam
BSwid
For future searchers of a solution like this.
I wanted to do the same but with a character value like a file name for the source file upon import.  It seems like you have to declare Character in the New Column function to get it to work right.  Otherwise, it just populates with missing values.  Thanks.
This didn't work:
dt << New Column(colName, Set each value(fileName));
This did:
names default to here(1);
dt = current data table();
colName = "SourceFile";
fileName = dt << get name;
dt << New Column(colName, Character, Nominal, Set each value(fileName));
This thread had it:  https://community.jmp.com/t5/Discussions/Set-Column-Values/td-p/13584
