learning_JSL
need jsl formula to account for empty cell in conditional if statement
Hi - I am new to jsl scripting and am trying to construct a jsl statement as follows:
if column A is empty, column C = empty,
else if column A < 500 and column B = 200, column C = 0,
else if column A>500, column C = 1.
How would I frame a jsl formula to do this?  Thanks!
ron_horne
Re: need jsl formula to account for empty cell in conditional if statement
@learning_JSL
try this:
names default to here (1);
dt = Current data table();
dt << new column ("C","Numeric", "ordinal", Formula (If(
		Is Missing( :A ),.,
		:A < 500 & :B == 200, 0,
		:A > 500, 1
10 REPLIES 10
learning_JSL
This is what I came up with after a thorough search of the jsl index, help menu, and google and lots of trial and error attempts....but it has not worked.   My formula for column C is:
formula(
	If(
		Is Missing( :column A ), Empty(),
		:column A < 500 & :column B == 200, 1,
		:columnA > 500, 0
ron_horne
@learning_JSL
try this:
		Is Missing( :A ),.,
		:A > 500, 1
learning_JSL
Thank you Ron.  The "empty" condition is not registering for some reason.  That is, if :A is empty, :C is 1.
ron_horne
@learning_JSL
try the edited version
learning_JSL
It now recognizes the empty cells and correctly populates them as empty (yay), correctly accounts for the 2nd condition and sets the 0's appropriately,  but it does not make it to the third (else if) condition.  That is, it is never 1 even though there are many instances when it should be.
ron_horne
is this correct?
New Table( "Untitled",
	Add Rows( 12 ),
	New Column( "A",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 12, 0 ),
		Set Values( [., ., 400, 400, 550, 550, ., ., 400, 400, 550, 550] )
	New Column( "B",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 5, 0 ),
		Set Values( [200, 61, 200, 66, 200, 60, 200, 51, 200, 61, 200, 65] )
	New Column( "C",
		Numeric,
		"Ordinal",
		Format( "Best", 10 ),
		Formula( If( Is Missing( :A ), ., :A < 500 & :B == 200, 0, :A > 500, 1 ) ),
		Set Selected
learning_JSL
I'll have to give this a try in the morning.  Thanks!
Watch out for the edge cases:
  • A == 500, exactly
  • A<500 and B != 200
It might be worth adding 999 as an otherwise value, just to get your attention if something slips through. If Secrets
If B is a missing value, the B!=200 test will not be TRUE or FALSE. The examples above will probably do what you expect, but if the B==200 is just before the final otherwise value (999, for example), and B is missing, it won't get the otherwise value (because not TRUE or FALSE) -- it gets missing.
learning_JSL
Thank you Craige.  Helpful tips to debug the formulas.  I appreciate it!
