jump
<< Get Values from a Column without subsetting each set of row selection.
So, I have a big dataset. Currently I am selecting few rows for each condition, subsetting the data and run  << get values (im My JSL script)  to move data to defined LIST.  This process is taking significant time, because as i mentioned dataset is huge.
I want to know, if there is a way to  << get values from a column for the selected rows without doing subset everytime. \
Or I have to subset every time to  << get values from  desired ROW\Column.
Thanks
Jeff_Perkinson
Re: << Get Values from a Column without subsetting each set of row selection.
You can get the value of a column for a given row by subscripting to that row.
For example:
dt=open("$SAMPLE_DATA\Big Class.jmp");
:name[1];
Will return "Katie" which is the name in the first row.
Likewise, you can use a matrix for the subscript.
:name[[2,3,4]];
That returns:
{"LOUISE", "JANE", "JACLYN"}
You can probably see where this is headed. The <<Get Selected Rows message returns a matrix, so you can use that to subscript directly to the column.
rows=dt<<get selected rows;
:name[rows];
-Jeff
Jeff_Perkinson
For example:
:name[1];
:name[[2,3,4]];
That returns:
:name[rows];
-Jeff
jump
Yes, thanks you. will try that.
