キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
peace
lack of fit test issues
Hello, I urgently need an answer before the deadline of my task. any quick answer will be highly appreciated.  the lack of fit test p-value and F2019-11-04 (5).png ratio are missing. what could this means. I have attached a screenshot of the results.
1 件の受理された解決策
受理された解決策
Re: lack of fit test issues
The Lack of Fit test is based on an analysis of variance. The test statistic is the F ratio. It compares the mean square for the pure error to the mean square for the lack of fit by ratio. Your mean square for pure error is 0. There is no variation between the replicate values.
元の投稿で解決策を見る
3件の返信3
peace
Thanks Mark. In other words, all I can interpret from the 'lack fit results' is that there is no variation between the replicants? What justification can I use to support the claim that there is no lack of fit then?
The lack of fit test, when possible, provides some evidence to decide if the estimated errors (residuals) in the current model are entirely random effects or a mixture of random and fixed effects. If it is the latter case, then the problem is model bias. All models should be validated with new empirical observations. Use the selected model to predict the outcome for factor levels / combinations that were not included in the data set that trained the model. Do the predictions confirm?
おすすめの記事
