tajrida
keyboard shortcut to rerun last dialog box used
Is there a keyboard shortcut to return to the dialog box you used most recently. Basically I am trying to find a quick and easy way to rerun your most recent analysis if you want to modify the settings and try it again.
Thanks
Mohammed Ahmed
Craige_Hales
Re: keyboard shortcut to rerun last dialog box used
I don't think there is a keyboard shortcut, but you can use the red triangle menu on the platform to bring up the launcher, already filled in.  Redo launches the platform without a dialog, useful if the data has changed.  Relaunch is what you want for changing launch settings.  You can then compare the results and close the one you don't want to keep.
Craige
Craige_Hales
Craige
