tajrida
keyboard shortcut to rerun last dialog box used
Is there a keyboard shortcut to return to the dialog box you used most recently. Basically I am trying to find a quick and easy way to rerun your most recent analysis if you want to modify the settings and try it again.
Thanks
Mohammed Ahmed
Re: keyboard shortcut to rerun last dialog box used
I don't think there is a keyboard shortcut, but you can use the red triangle menu on the platform to bring up the launcher, already filled in.  Redo launches the platform without a dialog, useful if the data has changed.  Relaunch is what you want for changing launch settings.  You can then compare the results and close the one you don't want to keep.
