FN
FN
k-fold cross validation in time series with JMP / JMP PRO
I want to use Bootstrap or Boosted Trees but with a k-fold method as I use it in the partition trees or neural nets. However I only see the option of adding a fix validation column.
Since I am working with time series, random samples cannot be used well to fit my models.
In addition to this, I am suspicious with the k-fold implemented in JMP as it always says random sample.
I am after a sequence like this one (at least):
And I think JMP does something like this (please confirm):
Here are all the options, the best for my case would be TimeSplit.
Any ideas or workarounds?
FN
FN
Re: k-fold cross validation in time series with JMP / JMP PRO
Confirmed: In JMP 14, K-fold it is actually a random sampling done k times.
FN
FN
And if the cutpointvalidation method is used as a column to fit trees (recommended for time series in JMP):
FN
FN
When using Neural Networks and the validation column, the results are a simple extrapolation. Test rows are not used in this interface either.
