radhi
jmp save
Hello
I ask why when I try to save a single group analysis in Jmp and open it again I cannot get back the models as already saved?
Thank you
jmp save
You can save the single group analysis using the Save button located on the SEM diagram window. To open a saved analysis, use the Open button on the diagram window.
