arnow
Using Variables in Dispatch
I am trying to manipulate the axes of a graph with Dispatch. The following code works well:
      Dispatch(
            "Precursor",
            ScaleBox,
{Min( 3395001600 ), Max( 3413404800 ), Interval( "Day" ), Inc( 5 ), Minor Ticks( 0 ), Rotated Labels( 1 )}
However, I need to script quite a number of graphs, so I would like to wrap them into a loop, which also works in principle (the graphs are created and the data displayed). What does not work, is the manipulation of the axes. The code I use is:
date_list= list("Precursor", "BL", "TCO");
i=1;
      Dispatch(
            date_list,
            ScaleBox,
This does not work. The message I get in the log is
Cannot find ScaleBox Subscript
Does JMP9 accept variables in Dispatch?
Any help is appreciated.
Cheers
Arno
ms
Super User (Alumni) ms
Try to store the code for the graph as an expression and then use Substitute() before evaluating the expression. I don't know why dispatch can't handle a variable. There are other situations I've run into in JSL where arguments just have to be quoted strings and I have still not figured out a way to tell which functions/messages that refuse to take a variable. Perhaps there is no logic, just that some jsl-functions are still in beta-version and may accept variables in future versions of JMP.
In any case, the eval(substitute)-method is a workaround that solves many of these situations.
An example:
Open( "$ENGLISH_SAMPLE_DATA/Big Class.jmp" );
somelist = {"1", "2"};
i = 1;
biv = Expr(
          Bivariate(
                    Y( :weight ),
                    X( :height ),
                              Dispatch(
                                        somelist[i],
                                        ScaleBox,
                                        {Min( 0 ), Max( 100 ), Inc( 5 ), Minor Ticks( 1 )}
Eval( Substitute( Name Expr( biv ), Expr( somelist[i] ), somelist[i] ) );
