is there a way to show the contours as Log scale instead of linear scale?
Hi All, is there a way to show the contours as Log scale instead of linear scale?
Peter_Bartell
Level VIII
Re: is there a way to show the contours as Log scale instead of linear scale?
Double clicking in the neighborhood of the axis on the Contour Profiler will bring up the traditional axis scaling modification window. From there you can modify the axis accordingly.
Kevin_Anderson
Hi, Ram!
Question: did you mean the axes, or the contours themselves?  More generally, what do you mean?
Peter nailed the axes.  But if you mean the contours, I think you may have a longer row to hoe.
ron_horne
hi ram.asra@gmail.com​,
i am not sure what you are looking for but perhaps this can give you a starting point
dt = Open( "$SAMPLE_DATA/Hurricanes.jmp" );;
// this produces the contures in linear scale
plot1 = dt << Bivariate( Y( :Latitude ), X( :Longitude ), Nonpar Density );
// extract the density to the data table
plot1 << (Curve[1] << Save Density Quantile);
plot1 << (Curve[1] << color by density Quantile);
// transform the density as you wish in a new column
dt << new column ("Ln Density", formula (ln(:Density)));
// plot the transformed density
dt << Contour Plot(
     X( :Latitude, :Longitude ),
     Y( :Ln Density ),
     Show Data Points( 0 ),
     Fill Areas( 0 ),
     Label Contours( 0 ),
     Transform( "None" ),
     Specify Contours(
          Min( -7 ),
          Max( -1 ),
          N( 7 ),
          Contour( 1, -7, -5793511 ),
          Contour( 2, -6, -8423637 ),
          Contour( 3, -5, -10725064 ),
          Contour( 4, -4, -12632256 ),
          Contour( 5, -3, -12885662 ),
          Contour( 6, -2, -13595764 ),
          Contour( 7, -1, -14828355 )
          Dispatch( {}, "Contour Legend", FrameBox, {Frame Size( 102, 235 )} )
// another plotting option - a mix of linear coloring and the log scale.
Scatterplot 3D(
     Y( :Latitude, :Longitude, :Ln Density ),
     Frame3D(
          Set Grab Handles( 0 ),
          Set Rotation( -56.0113386746381, -13.7470705335584, 1.38294617183857 )
best,
ron
pmroz
The forum software changed this line:
plot1 = DT << Bivariate( And( :Latitude ), X( :Longitude ), Nonpar Density );
Change And to Y to get it to work.
Jeff_Perkinson
I branched a thread from here on how Translation in the JMP User Community​ affects JSL.
-Jeff
-Jeff
