Inverse prediction is provided in the fitting platforms such as Fit Least Squares. The data table does not provide for an inverse prediction. You must manually solve for the desired variable in the model. You could then create a new column formula.
The Prediction Profiler is another tool that could help. You can set a goal for the Y variable and then it will maximize the desirability of the goal with the X settings.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '682194' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '682194') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '682194') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
