jtlam
interaction profiles
I did a fit model of each of the response and from the predicted formula from each response ran a profiler combing all the predicted formula and predicted SE.  When I look at the interaction profiles from the profiler, it's slightly different than the interaction profile of the fit model of the response.  Is there a clear explanation for this?
Thanks.
Re: interaction profiles
What is the nature of the difference between the two instances? Can you show us (post a picture of each instance)?
