Data_Mike
% in Column Name
Hello All,
There is an auto generated report which has the column name as % Adapter Bases.
I want to update from this report, however when I use the column name it gives me an error since % is in the beginning. Is there any workaround to this?
Data Table( "all data" ) << Update (
With( dtv ),
Match Columns( :SampleID = :sampleID),
Add Columns from Update table( :% Adapter Bases ),
Thanks!
Mike
Re: % in Column Name
 Try following syntax
:"% Adapter Bases"n
Scripting Guide > JSL Building Blocks > JSL Syntax Rules > Names
