AlexS
if filename contains help
Hello
I can't seem to open jmp data tables in a folder in which filename  contain "Values"
the log isn't telling me anything helpful either ...
i am sure its something obvious but i can't see the error!
Names Default to Here( 1 );
Set Default Directory( "C:\Users\" );
files = Files In Directory( "C:\Users\" );
For( i = 1, i <= N Items( files ), i++,
          If( contains( "Values",files[i]),
                    Open( files[i] );
Alex is the name, Power BI/ SQL /JMP is my game
ms
Super User (Alumni) ms
Re: if filename contains help
Try reversing the order of the arguments in Contain().
Contains( files[I], "Values")
ms
AlexS
could've sworn i tried that.....as if by magic this solves my issue thanks!
Sometimes you just need another pair of eyes!
