Françoise
html
bonjour,
avec JMP19, je n'ai plus l'html avec le thème foncé. Il apparaît comme avec le thème clair.
html réalisé avec publier dans le fichier
sachant que je suis en fond noir avec JMP19:
est-ce que vous avez le même problème ?
cordialement
7 REPLIES 7
Re: html
Hi @Françoise ,
JMP does not assume that if you are using Dark Mode that you want to export to Interactive HTML using the Dark Theme.
If you would like to export to Interactive HTML using the Dark Theme, please choose Dark Theme in the preferences:
~John
Praveena
Re: html
Hi @Françoise ,
Thank you for reaching out. If you are exporting the report as Interactive HTML, the themes can always be changed using the Themes Menu.
Best,
Praveena
Françoise
Re: html
hi,
I'd already selected the dark theme.
regards
Re: html
Hi @Françoise
Maybe there is something specific about what you were saving to HTML or how you were doing it.
In my reply, I assumed you were using File > Export > Interactive HTML or File Save As > Interactive HTML, but maybe that is not the case.
Can you please provide more details?
Thanks,
~John
Françoise
Re: html
bonjour,
j'ai sélectionné thème foncé
publier/publier dans le fichier.
Re: html
Thank you for those details @Françoise. Unfortunately, that method of creating Interactive HTML files is ignoring the Interactive HTML Theme preference in JMP 19 as you mentioned.
We hope to have this fixed in JMP 19.1.
As a work around, please use File > Export > Interactive HTML or File Save As > Interactive HTML.
Thank you for reporting the issue.
~John
Françoise
Re: html
thanks for your answer.
i'm waiting for HMP 19.1.
for your information, there is an another problem with HTML: I had a tabulate witth offset columns:
see JMP Technical Support - Case TS-00236295
thanks to solve this problem with JMP 19.1 because this is very boring.
regards
