emails4nir1
how to make jmp show the risk ratio automaticly for all the "fit proportional hazards"?
1- when analyzing a parameter and its influence on survival with cox-fit proportional hazards, I want it to show me the risk ratio automatically. is that possible?
2- is there a way to check multiple parameters at the same time (since asking jmp to analyze a few parameters with the fit proportional hazards makes it multivariate analysis, and I don't want to do change the parameter manually to see its separate significance)
thank you very much
jiancao
Re: how to make jmp show the risk ratio automaticly for all the "fit proportional hazards"?
1. To have risk ratios reported automatically go to File => Preferences and check the Risk Ratios box.  11855_pastedImage_0.png
2. If you want to check the significance of multiple parameters (associated with a categorical effect) as a whole you can use Likelihood Ratio Tests or Wald Tests options available in the right top red triangle . You will get the effect tests reports.
