bk
bk
how to make a subset of a table and append data from loop
I have a set of data, (see attached). i want to check every row on a column (against a certain criteria) and then isolate rows that do not meet that criteria and subset them into a new data table. i want to be able to repeat this for multiple columns (where each has its own criteria) and continue adding to this subset table that i originally created. i'm having some trouble with this and was hoping if someone could help.
here is what i was doing:
path = "xxxxxxx/";
data_table = Open( path || "Sample Data.jmp" );
Sub_Table = New Table( "Rejected Parts Table", invisible );
New_table = data_table;
For( k = 1, k < N Col( New_table ), k++,
	Print( k );
	New_table << select where( Column( 1 + k )[] >= 0.2 | Column( 1 + k )[] <= 0.02 );
	alp = New_table << Subset( Selected Rows, output table name( "subset" ) );
	alp << Concatenate( Sub_Table, output table name( "Rejected Parts Table" ) ) <<
	Save( path || "Rejected Parts.jmp" );
	Close( alp );
	New_table << delete rows();
pmroz
Re: how to make a subset of a table and append data from loop
This one was a bit tricky.  The main fix is to use AS COLUMN in your select statement.  I changed the logic to use get rows where and build up a list of rows to subset/delete.  The get_unique_values function is courtesy of this forum!
get_unique_values = Function( {in_list},
	{Default Local},
	tmp = [=> 0];
	Insert Into( tmp, in_list );
	tmp << get keys;
path = "c:\temp\";
New_table = Open( path || "Sample Data.jmp" );
all_selected_rows = [];
	Print( k );
   	selected_rows = new_table << get rows where( As Column( 1 + k ) >= .2 | As Column( 1 + k ) <= .02 );
// Append the rows we just found to the master list
   	If( N Rows( selected_rows ) > 0,
		all_selected_rows = all_selected_rows |/ selected_rows
// Convert matrix to a list and get unique values
all_selected_list = get_unique_values( As List( all_selected_rows ) );
alp = New_table << Subset( rows( all_selected_list ), output table name( "Rejected Parts Table" ) );
alp << Save( path || "Rejected Parts.jmp" );
Close( alp );
New_table << delete rows( all_selected_list );
ms
Super User (Alumni) ms
An alternative approach using the same criteria for all columns:
dt = Data Table( "Sample Data.jmp" );
r = Loc( V Sum( Transpose( !(0.02 < dt << get as matrix < 0.2) ) ) );
dt << Subset( rows( r ), output table name( "Rejected Parts Table" ) );
dt << delete rows( r );
Slightly more complicated when each column has its own criteria, for example:
upper = [0.2 0.3 0.2 0.4 0.2];
lower = [0.02 0.03 0.02 0.04 0.02];
r = Loc( V Sum( Transpose( !(Repeat( lower, N Row( dt ) ) < dt << get as matrix < Repeat( upper, N Row( dt ) )) ) ) );
