Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
TONYMA
how to input picture in JMP?
dear, how to input picture in JMP? thanks
you are your god.
Re: how to input picture in JMP?
Here is an example taken from the Scripting Guide
     Help==>Books==>Scripting Guide
Import Images from a Web Page
You can import images on the web into a data table, using the Expression data type. The following example creates a new data table and adds two images to it.
dt = New Table( "test", New Column( "Image", Expression ) );
dt << Add Rows( 1 );
dt:Image = New Image( Open( "http://www.jmp.com/support/help/13/images/MosaicPlot.png" ) );
dt:Image = New Image( Open( "http://www.jmp.com/support/help/13/images/tTest_NoLoc.png" ) );
