robust1972
how to find the empty columns and delete them by scripting
how to find the empty columns and delete them by scripting. any helps and/or hints will be very appreciated.
ms
Super User (Alumni) ms
Re: how to find the empty columns and delete them by scripting
I can think of several ways to do this. Here's an example based on the built-in Missing Data Pattern command.
names = dt << Get Column Names();
dt1 = dt << Missing Data Pattern(columns(Eval(names)), invisible);
n = N Row(dt1);
For(i = N Col(dt), i >= 1, i--,
    If(Col Sum(Column(dt1, i + 3)) < n,
        Remove From(names, i)
Try(dt << delete columns(names));
Close(dt1, nosave);
ms
n = N Row(dt1);
Close(dt1, nosave);
ian_jmp
Level X
As an alternative (and probably one of Marcus' 'several ways'):
dt = CurrentDataTable();
m = dt << getAllColumnsAsMatrix;
// Loop over the columns and record which are entirely missing
c2del = {};
for(c=1, c<=NCol(m), c++,
if(NRow(Loc(IsMissing(m[0,c]))) == NRow(m), InsertInto(c2del, c));
// Delete the columns
dt << deleteColumns(c2del);
