Here is the script to input your data
I used the JMP Excel Wizard to open the file interactively and then copied the Source script that JMP created to place into the script. The script reads in the file twice. First to read the data, and then the second time to read in the Lot ID. I then just added the code to let you select the Excel file to import, and the JSL required to create the new Lot ID column.
names default to here(1);
path = Pick File();
dt = Open(
path,
Worksheets( "Sheet1" ),
Use for all sheets( 1 ),
Concatenate Worksheets( 0 ),
Worksheet Settings(
1,
Has Column Headers( 1 ),
Number of Rows in Headers( 7 ),
Headers Start on Row( 6 ),
Data Starts on Row( 13 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 0 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Suppress Empty Columns( 1 ),
Treat as Hierarchy( 0 ),
Multiple Series Stack( 0 ),
Import Cell Colors( 0 ),
Limit Column Detect( 0 ),
dtLotID = Open(
path,
Worksheet Settings(
1,
Has Column Headers( 0 ),
Data Starts on Row( 3 ),
lotID = dtLotID:Column 2[1];
close(dtLotID, nosave );
dt << New Column("Lot ID", Character, set each value(lotID));
