fionaweston
how to count the number of columns in each row of data that fall below a certain value
If I have 4 columns in my table and I need to find out per row how many columns fall below 98% how can I write a simple formula to do this.
There are some similar post but they are way more complicated than I need.
Thanks
3 ACCEPTED SOLUTIONS
Georg
Re: how to count the number of columns in each row of data that fall below a certain value
Probably this formula could do:
test = Function( {val},
	If( val < 0.98, 1, 0 )
Sum( test( :A ), test( :B ), test( :C ), test( :D ) );
Georg
SDF1
Hi @fionaweston ,
  To expand and generalize what @Georg posted, this script you can save to any data table and it will generate a new column with the counts. I wanted to add this because you mentioned that the data table could have hundreds of columns, and this can handle that, as well as however many rows you have.
dt << New Column( "Counts", Numeric, Continuous );
For( r = 1, r <= N Rows(), r++,
	count = 0;
	ret = 0;
	For( col = 1, col <= N Col() - 1, col++,
		If( Is Missing( Column( col )[r] ) == 1,
			count = 0,
			count = test( Column( col )[r] )
		ret += count;
		:Counts[r] = ret;
  You just click the hot button next to your data table name and select New Script, then copy/paste the script from above into the new script (and give it a name of course) and then click the green arrow to run it. You can then copy/paste that script into any data table -- of course, you would change the comparison value in the "test" function for whatever data set your using.
Hope this helps!,
DS
UPDATE: I noticed my original post didn't account for missing values in a column and corrected it to account for missing values.
SDF1
Hi @fionaweston ,
  As mentioned, here is the data table mock-up I did with the Counts script. It will only count numeric/continuous columns and ignore any other data/modeling type columns in your table.
Hope this helps!,
DS
8 REPLIES 8
fionaweston
This is just a short version. The real table could have 100+ columns.
Georg
Georg
fionaweston
Thanks Georg, that works!
SDF1
Hi @fionaweston ,
	count = 0;
	ret = 0;
			count = 0,
		ret += count;
		:Counts[r] = ret;
Hope this helps!,
DS
fionaweston
Thanks Diedrich,
This is awesome!
SDF1
Glad to hear it works for you!
SDF1
Hi @fionaweston ,
Hope this helps!,
DS
fionaweston
That helps enormously Diedrich.
Thankyou
