Theresa
how to change one column to percentage format
Like change the weight column to persentage:
how to covert the "weight" column as  "95/100*100"=95%. 95% as the final result?
                        height  weight
KATIE small F    59    95
LOUISE small F 61 123
Re: how to change one column to percentage format
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
for each row(
     :weight = :weight / 100;
dt:weight << format("Percent",7,2);
Percent format uses 1 as 100%, and any decimal value less than 1 as the percent of 1.  Therefore .59 will be displayed as 59%
