JMP2021
how to assign color by group when making a line graph?
I want to assign the same category (dye) in the same color when making a plot.
see plot below.
I would like to assign all the C560 plotted lines in orange instead of different colors. all the FAM in green.
I want to keep individual line not a line with the mean of the group.
Re: how to assign color by group when making a line graph?
  1. Sort the data table by RepID & Condition and Cycle Number
  2. Run dRn vs. Cycle Number table script
    1. From the red triangle select Show Control Panel
    2. Drag the Dye column to the Color drop area
    3. In the Line properties in the Control Panel, select the Row Order check box
I believe that gives you what you want
hogi
Level XIII
you can use the value color property of the column and define the same color for multiple entries:
... alternatively you can define a new column which can be used for the COLOR - and continue to use your original column as Overlay.
Here is an example with Measles data from the STIPS course. Separation by Region is just applied to clearly see the different color groups.
Open( "$SAMPLE_STIPS/Measles.jmp" );
Graph Builder(
	Size( 1061, 493 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables(
		X( :Year ),
		Y( :Cases ),
		Group X( :Region ),
		Overlay( :State Abbr. ),
		Color( :Region )
	Elements( Line( X, Y, Legend( 5 ) ) )
JMP2021
That is very helpful.
One more question is that what does this Row order selection does to the graph.
It uses the order of the row to connect from point to point
JMP2021
thank you.
